| Version(s): | All | ||
| Subarea: | Materials | ||
| Original Author: | Modestas Turulis. Bentley Technical Support Group | ||
The analysis ends up with such error in the Output file:
*** STAAD.Pro ERROR MESSAGE ***
DENSITY NOT PROVIDED. SELFWEIGHT COMMAND IGNORED
Why?
This error indicates, that the program cannot identify what density of the material should be used to calculate this selfweight of the structure. Usually, this happens if the material properties are not assigned to the members/plates/solids. To assign the material, go to the Material page, select the required material from the Materials' list and click assign:
