Display references in a different color
  Product: MicroStation
  Version: V8i, CONNECT, 2023 - 2025
  Environment: N\A
  Area: Reference
  Subarea: N\A
How to display references in a different color to the active/live elements
When working in a file that has a number of references attached, it would be useful to display the references in a different color so that they are recognisable as references at a glance
Option 1
  1. In the master file, open the Level Manager
  2. On the left hand side, expand the tree under the master file name
  3. Select one of the references - the levels for that reference should display in the main section
  4. Change the Symbology toggle from 'ByLevel' to 'Overrides'
  5. Select all the levels in the reference file (left click once on the first level name and hold down the button while dragging down to select multiple levels)
  6. Click in the Color column for one of the levels and select the desired color to display the references
  7. Repeat steps 3 to 6 for any additional references
  8. Open the References dialog
  9. Select a reference and click on the Presentation button (or right click and choose Presenatation)
  10. In the Presentation dialog, turn on the 'Use View Flags' option, enable the Level Overrides toggle and click on OK to apply - the reference elements should change color
  11. Repeat steps 9 and 10 for any additional references
  12. See video below showing this process
Option 2
  4. Ensure the Symbology toggle is set to 'ByLevel'
  7. Repeat steps 3 to 6 for any additional references - the references should display in a different color
Note: Option 2 will only work if the reference elements have been placed with ByLevel Attributes in the reference file itself
Note: The Key-in: set refleveloverrides on    needs to be set for either option to work
Determining Attribute ByLevel Status
Other language sources
Deutsch
  Original Author: Conor King
