| Issue Number | Description |
| 137969 | Resolved issue when replace mirrored cell containing text. |
| 448928 | Fixed issue with Notes Text Justification shifting when Annotation Scale is changed. |
| 560829 | Resolved issue with specific file taking a long time to open. |
| 640876 | Fixed issue with Place Label> Horizontal Attachment> ‘Auto’ is not working on all cells. |
| 694124 | Fixed issue with place 'Date Plotted' File Property field. |
| 694420 | Resolved issue with "Ignore locate interiors" setting under Preferences-Raster not correctly working if Preferences-Input-Locate interiors are enabled. |
| 724866 | Fixed specific issue when changing element level in MicroStation Connect taking an extended period of time. |
| 726432 | Fixed issue with Nested reference's Display switch is turned ON by Reference Copy. |
| 727440 | ‘Geometric Tolerance’ tool is available in Dimensions toolbox. |
| 728163 | Fixed issue with changing references to Cached visible edges causes elements to change color. |
| 733299 | Resolved issue with Arcs added to imprints with an inner loop. |
| 737541 | Fixed specific issue with Text orientation lost when Merged into Master. |
| 756973 | Resolved issue with exporting Coordinates accuracy option. |
| 778939 | Resolved specific issue with certain file hangs while exporting to STEP. |
| 798901 | Resolved issue with Chamfer distance/angle incorrect. |
| 800638 | Fixed issue with Measure Distance Perpendicular with Flatten Direction View Z showing incorrect result. |
| 853265 | Animation producer keyframe graph window shrink on every time we edit Animation Producer Window size. |
| 854770 | Fixed issue with pattern map is scaled on element in FBX file when file is exported to FBX. |
| 861153 | Resolved issue where Upgrade Tag only shows 7 Tags at a time for Upgrading. |
| 863125 | Fixed issue with Define Sheet Border tool incorrectly rescaling the Sheet Boundary. |
| 865313 | Fixed issue with specific file that was Unable to Cut Solid with Curve. |
| 865905 | Improved performance with Modify Solid with Modify Face. |
| 885315 | Resolved issue where Select by Text Styles was not correctly working. |
| 888321 | Fixed issue with Luxology dialog not updating to show light setups present in active model when we shift from one model to another in same file. |
| 891704 | Resolved issue with Measure Area > Method: Union. |
| 892964 | Fixed issue with Display Rule using default value of the 'Property Type' created, instead of the one that is used. |
| 892975 | Fixed issue with Display Rule does not shows new 'Property Type' in the Generate Dialog. |
| 895361 | Resolved issue when changing GCS the position of reprojected references is not automatically updated. |
| 901303 | Fixed issue with Line segment details table missing. |
| 901422 | Fixed specific issue where Level Descriptions are being changed when modifying Level Override symbology. |
| 903807 | Fixed issue with Georeferenced JPG file not fully loading. |
| 910939 | Fixed issue with not able to save specific DGN file to DWG. |
| 913265 | Resolved issue with Text Favorite not copying associated text styles from dgnlib to local dgn. |
| 916676 | Fixed issue with Dimension Angular> Angle Between Lines> turn ON ‘Start Extension’ causes ‘End Extension’ to activate. |
| 916698 | Fixed issue with Dimension Angular> Angle Between Lines> ‘End Extension’ option. |
| 919546 | Resolved issue with specific file where Create Region Flood fill not correctly filling. |
| 926644 | Resolved issue with Default Model View Group from 2D seed named incorrectly. |
| 927927 | Fixed issue with Visible edges incomplete when rendering with high resolution. |
| 928392 | Fixed issue with Orientation of Material attachments is incorrect when we export given file to SketchUP. |
| 932306 | Resolved issue with importing specific STEP file taking a long time. |
| 938911 | Resolved issue with Pattern of material scaled down after exporting to FBX. |
| 939068 | Fixed issue with imprinted Geometry does not stay on respective face if geometry of a solid changes. |
| 940664 | Resolved issue with Enter Data Field changes color to 0 when edited. |
| 941513 | Fixed issue with using Levels from a DGNLIB in Multi-line definition. |
| 941556 | Fixed issue with Quick Properties that was removed (Alt + Right click). |
| 942787 | Resolved issue when creating a WorkSet using an existing WorkSet as a template, the existing files & folders used are not determined by the existing WorkSet.cfg file. |
| 944399 | Improved the time taken to switch from MicroStation to Backstage. |
| 947755 | Resolved issue with Text in mirrored cell display. |
| 949983 | Improved the time to show properties of element on Properties dialog. |
| 954357 | Improved performance when First File Open time, when there are large list of Pinned WorkSets. |
| 963019 | Resolved issue with Hatch pattern are not getting displayed in section cut graphics. |
| 963565 | Fixed issue with Measure Distance Along tool will not allowing to switch between elements by doing right click if elements are overlapped. |
| 964523 | Resolved issue with specific file where the reference containing pattern was unable to be moved. |
| 967610 | Resolved issue where Browse button in Import-Export Coordinates tool opens to "C:\Windows\System32" directory always. Instead should open to last used directory. |
| 968870 | Fixed issue with specific file with Points placed on element are not snappable. |
| 988808 | Resolved issue where Tool Settings box moves on Update View. |
| 999646 | Resolved issue where Editing mesh causes material information lost. |
| 1005783 | Resolved issue where Blocks/Attributes from Xref. file is rotated in specific file. |
| 1006923 | Fixed issue with Element Selection Inside or Overlapping Area not selecting elements in specific file. |
| 1009619 | Message center shows follow link failed while opening the PDF file name which is in other language except English. |
| 1009630 | Fixed issue with specific DGN file not saving correctly as DWG. |
| 1009781 | Resolved issue with specific file that has attached files to printing to PDF. |
| 1011531 | Resolved issue where specific 3D PDF files are missing elements. |
| 1012525 | Resolved issue with Background color is not applied by Display Rules in Wireframe views. |
| 1012762 | Resolved a crash where placing field for item type property which contains special characters. |
| 1012904 | Resolved issue with a crash when dragging a fence in a specific file. |
| 1014396 | Resolved issue with texture mapping not correctly converted in to FBX. |
| 1014889 | Resolved issue with _USTN_CAPABILITY < -CAPABILITY_BYLEVEL not correctly working in specific situation. |
| 1018662 | Fixed issue with large dimension arrow heads in specific DWG file. |
| 1018998 | Resolved issue with Levelaudit crashing when entering report nullnames. |
| 1021015 | Fixed issue with crash while opening specific IFC file. |
| 1021257 | Fixed issue with opening specific file crashes. |
| 1021968 | Resolved issue where incorrect area calculation for identically same shapes in specific file. |
| 1022120 | Fixed issue where file is unable to import this IGES file. |
| 1023412 | Resolved issue with Text placed along curved element changes position when edited or modified in specific file. |
| 1024680 | Fixed issue with Design File Cleanup fails / takes longer time to find duplicates in specific file. |
| 1026618 | Resolved issue with WMS map attachment fails. |
| 1027112 | Resolved issue unable to edit the feature of a Solid by Extrusion Along Path with inter diameter as 0 in specific file. |
| 1027356 | Fixed issue with Images created using HTML Cell Library are distorted. |
| 1028022 | Fixed issue with Bing Map feature does not work because of reprojection errors for British Nat Grid. |
| 1028374 | Resolved issue with Cells Placed on wrong level in specific file. |
| 1028559 | Fixed issue with New Customized Tabs are missing not visible. |
| 1028621 | Fixed issue with commands applied to customized ribbon disappears if they come from Choose components from TAB. |
| 1028708 | Resolved issue with empty curve was resulted in a crash. |
| 1029219 | Resolved issue with Vissim data and Geometry does not match on export as vissim data placed far away from Geometry. |
| 1029417 | Resolved issue with Level display not working properly - turn off but still visible. |
| 1029428 | Fixed issue to create new level, activate it & then creating elements on it does not display those element. |
| 1029684 | Resolved issue to interpret the GCS in specific ContextCapture generated 3MX. |
| 1030159 | Resolved issue with specific file when MicroStation crash on Exporting File to LumenRT. |
| 1031587 | C# SDK Interface Problem of Bentley.DgnPlatformNET.Modify |
| 1031881 | Fixed Crash Converting Meshes to Solid in specific file. |
| 1032160 | Resolved issue where 'Revert customizations for selected Ribbon item' is constantly greyed out. |
| 1032549 | Fixed issue with Data File Clean Up remove arcs even though they are not duplicate. |
| 1032855 | Fixed issue with Level display not working properly with level names containing umlaut. |
| 1033555 | Resolved issue with Sheet Index does not number the sheets correctly for sub-folders (child folders). |
| 1034205 | Fixed File-specific file crash. |
| 1034698 | Fixed the issue with the normal are reversed for Extract Points from a Surface/Face tool compared to V8i. |
| 1034709 | Resolved issue with the normal of created surface are reversed to Surface tool compared to V8i. |
| 1034818 | Fixed issue with DWG tables resized when modified. |
| 1035819 | Fixed issue with Stencil creates separate line segment for each mesh surface instead of creating continues line. |
| 1036131 | Fixed Cut Solid with Curve : while using Line as a cutting profile, Tool shows incorrect Cut Direction (portion to be removed). |
| 1036178 | Fixed Cut Solid with Curve : while using Line as a cutting profile, Cut Direction Arrow (indicating portion to be removed) is not visible instantaneously. |
| 1036195 | Fixed Cut Solid with Curve : Not able to control the cutting profile curve projection. |
| 1036618 | LOB placed under Custom path wont found for Proxy replace when we export file from MicroStation to LumenRT. |
| 1036901 | Fixed issue with MicroStation closing when trying to open a certain file. |
| 1037645 | Resolved issue with Array Along Path Tool generates incorrect Preview on copied and New Parametric Solids. |
| 1037870 | Fixed issue with Mirror Copy (2D Manipulation) of Profile based Solids (having 2D Parametric cell as Profile) shows Profile as Extended element instead Parametric Cell. |
| 1037986 | Resolved issue with using Stretch/Fence Stretch on cell which having Parametric solid that could cause crash. |
| 1038433 | Fixed issue to attach specific POD file. |
| 1038453 | Fixed issue with displaying AutoCAD rotated mtext (callouts) correctly. |
| 1039083 | Resolved issue to Manipulate (Move/Copy/Rotate)multiple parametric cell instances after updating variables value for some instances. |
| 1040301 | Fixed issue with Cell Selector dialog is not following aspect ratio in which csf file has been saved. |
| 1041096 | Resolved issue with Active Angle key-in "AA" does not work for Parametric cells. |
| 1041995 | Fixed issue with Shared cell located in undisplayed level became displayed by Zoom Out. |
| 1042280 | Fixed issue with Extract Iso-Curves tool not responding on Bspline Surface. |
| 1042369 | Fixed issue with DWG Multi-leaders having own annotation scale not matching Models annotation scale. |
| 1042772 | Resolved issue with specific File crash when opened. |
| 1045257 | Fixed issue with imported STEP file with missing elements. |
| 1045368 | Fixed issue with Level Display is changing when opening specific file created in V8i. |
| 1046697 | Resolved issue with Numeric input for position mapping not working. |
| 1047433 | Resolved issue with specific crash when opening View 3 in Default View Group. |
| 1048002 | Fixed issue with specific file that crashes upon open. |
| 1049248 | Fixed issue with Texture map path not being found if texture maps defined are in sub folder on same root of dgn folder when the material map path contains a partial directory. |
| 1049681 | Resolved issue with unable to see elements from specific V7 file. |
| 1049996 | Fixed issue with Selecting and deleting a long list of materials from palette leads to a crash. |
| 1050060 | Fixed issue using Fence File (FF=) with a reference file containing Smart Solids. |
| 1050801 | Fixed issue with Rtext not displaying. |
| 1050885 | Resolved Visible Edge setting set through variable is does not get applied when attaching reference through drag and drop method only. |
| 1051124 | Fixed issue with Label coordinates (xyz text) tool in DWG workmode not working correctly. |
| 1051565 | Resolved issue with exporting to ACIS SAT version 6.0 is fails for units mm. |
| 1052409 | Fixed issue where MS_REF_MAXNESTDEPTH does not get applied when attaching reference through drag and drop method only. |
| 1052601 | Scaling (2D Manipulation) of Profile based Solids (having 2D Parametric cell as Profile) shows Profile as Extended element instead Parametric Cell |
| 1052735 | Fixed issue Mleaderline and MText color changed on Copy and Save. |
| 1053525 | The extracted Edge by Extract Faces/Edges tool moved from original location. |
| 1054571 | Fixed issue converting mesh to SmartSolid causing a crash. |
| 1054743 | Resolved issue with Boolean Operation 'Unite Solids' creates incorrect results with Mirrored Solids (Merge Parametric Solids : ON). |
| 1054959 | Fixed issue with Feature Array Along Path Tool generates incorrect Result if Base Solid (Slab) is generated in a specific way. |
| 1056131 | Fixed issue with Copied Annotation with a Text frame Box, rotates the box. |
| 1056358 | Fixed issue with Texture map not seen on element if make a same material copy and attached to another elements. |
| 1056526 | Fixed issue with Quick Properties dialog shows cut off at the bottom of the dialog depending on which elements selected for quick review. |
| 1058003 | Resolved issue with disabling Autosave preference locks files. |
| 1058501 | Resolved issue with specific File created by Save as DXF can only be opened by MicroStation CONNECT not V8i. |
| 1059060 | Fixed issue with speciific file converted from DWG to DGN in MicroStation CONNECT fail to convert back to DWG. |
| 1059235 | Fixed issue with Fit View on raster clip not working correctly. |
| 1059668 | Resolved specific issue with Trims Solids not working in specific file. |
| 1060497 | Resolved issue with Background color from Element fill color override is not applied by Display Rules. |
| 1061144 | Fixed issue with Ribbon status not staying minimized. |
| 1061545 | Resolved issue that Polygon Collection disappear. |
| 1061575 | Resolved issue with Save As V7 and specific file crashes when working in V7 workmode. |
| 1061606 | Improved opening time with specific DWG file with Text takes 25 % more time to open than V8i |
| 1061607 | Resolved issue with specific DWG file with lines takes that take an extended period of time to open compared to V8i. |
| 1061608 | Resolved issue with specific DWG file with shared cells takes extended time to open. |
| 1062662 | Fixed issue with Feature Array Along Path Tool generates incorrect Result if Base Solid (Slab) is generated in a specific way. |
| 1062843 | Fixed issue with ECW file incorrect space. |
| 1063036 | Resolved issue with Fill not displaying in specific file. |
| 1063051 | Fixed issue with crash when importing IFC. |
| 1064075 | Fixed issue with Exterior Render Setups: Any change disables Antialiasing. |
| 1064168 | Resolved issue with description of datum NAD83/2011. |
| 1064264 | Resolved issue when exporting Item Types instance data results in a crash. |
| 1064532 | Resolved a crash in specific file while opening file. |
| 1064700 | Resolved issue with Compress a particular file results in a crash. |
| 1065238 | Resolved issue with ESPG:4019 Coordinate System is in incorrect units |
| 1066205 | Resolved issue with crash on opening files with Design History with specific file. |
| 1066513 | Fixed issue with B-spline by Tangent does not work with Arcs. |
| 1066532 | Fixed issue in a reference file that has locate column turned off. If locate is turned off the geometry in the reference file should not be located |
| 1069658 | Fixed issue with 2D file, where some backward elements coming in front when creating a Group of selected elements. |
| 1070282 | Resolved issue with specific file where Measure Area result is incorrect. |
| 1070527 | Resolved issue with missing Belgium GCS: EPSG:31370B – New Belge Lambert 72. |
| 1074732 | Resolved issue with crash on opening specificfile with certain display style |
| 1075684 | Resolved issue with WorkSet Template Custom Properties not copied to new WorkSet. |
| 1075695 | Fixed issue with Link containing multiple keyins does not parse keyin arguments correctly. |
| 1075765 | Resolved issue with Display problem with revolved surface. |
| 1076143 | Resolved issue with implementation of OSTN15 transformations. |
| 1078291 | Resolved issue with GCS shift error for Custom Coordinates. |
