Beam - Girder Connections
Beam - Girder Joints
In RAM Connection, Beam - Girder (BG) Joints can be created with the following configurations:
Shear Connections
Connector
Design Code Girder Section Beam Section Joint/Connection Options
  • AISC: Single Plate (SP)
  • AS: Web Side Plate (WSP)
  • BS: Fin Plate (FinP)
  • CSA: Single Plate (SP)
  • EN: Fin Plate (FinP)
  • GB: Single Plate (SP)
  • IS: Web Side Plate (WSP)
  • NZS: Web Side Plate (WSP)
  • I-Shaped
  • I-Shaped
  • C-Shaped
  • Beam Skew Angle: Max 60º
  • Beam Slope Angle: Max 45º
  • Plate Type: Standard or Extended
  • AISC: End Plate (EP)
  • AS: Flexible End Plate (FEP)
  • BS: Flexible End Plate (FEP)
  • CSA: End Plate (EP)
  • EN: End Plate (EP) or
  • IS: End Plate (EP)
  • NZS: Flexible End Plate (FEP)
  • I-Shaped
  • I-Shaped
  • C-Shaped
  • Connection Type: Bolted or Welded
  • AISC: Clip Angle (DA)
  • AS: Angle Cleat (AC)
  • BS: Double Angle Web Cleat (DAWC)
  • CSA: Double Angle (DA)
  • EN: Double Angle Web Cleat (DAWC)
  • GB: Double Angle (CA)
  • IS: Double Angle Web Cleat (DAWC)
  • NZS: Angle Cleat (AC)
  • I-Shaped
  • I-Shaped
  • C-Shaped
  • Angle Type: Single or Double Angle
  • AISC: Standard Tee (ST)
  • I-Shaped
  • I-Shaped
  • C-Shaped
  • AISC: Bent Plate (BP)
  • I-Shaped
  • I-Shaped
  • Beam Skew Angle: 5º < θ < 70º
  • Plate Type: Single or Double Plate
  • AISC: Double Shear Plate (DSP)
  • Rectangular
  • Rectangular
In addition to the connection specific options listed in the table above, the following beam member parameters in beam-girder connections can be customized in the connection pad:
Moment Connections
Connector
  • AISC: Flange Plate (FP)
  • I-Shaped
  • I-Shaped
NOTE: Beam-Girder alignment cannot be modified. The top flange of the beam and girder will be set at the same elevation for the FP beam-girder moment connection.
