| Version: | V8i, CONNECT | ||
| Area: | Graphics Display | ||
| Subarea: | General |
Key-in set construct on/off/toggle does not work
Tool 'update view' can be used to see the difference after using of the key-in Set construct on/off/toggle
Key-in construct on/off/toggle works without ‘update view’ but the view needs to be clicked on with a left mouse button and zoom a bit in and out.
Combined key-ins: set construct on; selview all; update view extended
