RAM Connection can be used as a standalone solution or in conjunction with an analyzed STAAD.Pro, RAM Structural System, or RAM Elements model.
The integrated solutions allow transfer of model data (including joint data, load cases/combinations, design forces) to ensure an accurate and convenient workflow.
In RAM Connection, connections can be designed and verified according to the following standards:
In RAM Connection, international connection databases are available and will be used in conjunction with the selected design code.
In RAM Connection, you can design connections for a variety of joint types, including beam-to-support, splice, base plates, and bracing joints. In addition, several connections in RAM Connection can be designed with the following joint configurations:
Beam Section Types: Prismatic, Haunched, or Tapered |
Column Section Types: Prismatic or Tapered |
Beam Sections: I-Shaped or Channel |
Column Sections: I-Shaped, Rectangular, or Circular |
Skew Angle |
Slope Angle |
Vertical Beam Splice Angle |
Beam-to-Support: Mitred Knee |
Beam Splice: End Plate |
In RAM Connection, you can design connections for a variety of different joint configurations.
In RAM Connection, you can design tubular connections for several US and international design standards.
RAM Connection provides easy to use CAD details of designed connections which can save detailing time and reduce errors.
In RAM Connection, Steel Connection Reports can be view/printed for each connection. These reports include all of the geometric considerations and design checks, along with the formulas and code references, that were performed.
In RAM Connection, the ANSI/AISC 358-16 seismic prequalification requirements can be considered for intermediate and special moment frames.
