| Version: | V8i, V8i (SELECTseries) | ||
| Area: | Graphics Display | ||
| Subarea: | Display Styles |
Shapes, such as circles and rectangles, when drawn, always display with as filled, even when the option 'Fill Type' is set to 'None'
The reason the shapes are showing up as filled is due to the type of Display Style being used in the view. Change the Display Style (or View Display Mode) to Wireframe to show the shapes without a fill. To do this;
or
| Original Author: | Conor King |
