| | Applies To | | |
| | Product(s): | MicroStation | |
| | Version(s): | V8i, V8i (SELECTseries) | |
| | Environment: | N\A | |
| | Area: | Graphics Display | |
| | Subarea: | Display Styles | |
| | Original Author: | Conor King, Bentley Technical Support Group | |
How to place something drawn in 3D onto a drawing (sheet) and just show the solid part without wireframe
When drawing an object in a 3D model, it may be desired to show as more of a solid view in a drawing (a sheet model) without the wireframe showing.
- Draw the object in a 3D Design Model
- Attach this as a reference to a 2D Sheet Model
- To display the attachment as a solid (no Wireframe), apply one of the Shaded Display Styles such as Illustration or Smooth
- To do this, use the 'Set Reference Presentation' tool with the Reference selected/highlighted in the References dialog
- From the Reference Presentation dialog, choose one of the shaded Display Styles, e.g. Illustration and click on OK
- See a short video showing this...
https://youtu.be/Dbr5jarFrl0
Other Language Sources
Deutsch
