| Version(s): | V8 | ||
| Area: | Text | ||
| Subarea: | Word Processor | ||
| Original Author: | Jonna Laitinen, Bentley Technical Support Group | ||
The following error occurs when attempting to edit text using the Word Processor mode:
Unable load/create dialog item of type 'HTML', id=41510001 from dialog "Text Editor - Word Processor".
Note: This applies to MicroStation V8 XM edition or MicroStation V8i running on Windows Vista or Windows 7 and often when Internet Explorer 8 or newer is installed.
Please ensure that you have installed the appropriate MicroStation pre-requisite pack.
You can also get the DHTML control directly from the Microsoft web site.
Note: This solution works for Windows Vista and Windows 7.
DHTML Editing Control for Applications Redistributable Package (x86)
