| Version(s): | 08.11.09.459 | ||
| Area: | GUI | ||
| Subarea: | Dialogs |
Occasionally, my "Tool Setting" dialog box gets lost or hidden somewhere, how could this be avoided.
3. Select the dialog through the view pulldown or through the window list select the dialog and use the Windows AeroSnap shortcut (WINKEY + directional key). The dialog should then be moved to the nearest screen
Restore Tool Settings Dialog: https://bentleysystems.service-now.com/community?id=kb_article_view&sysparm_article=KB0112655
| Original Author: | Judy Wong |
