| Version: | V8i, V8i (SELECTseries), CONNECT Edition | ||
| Area: | UI Customization | ||
| Subarea: | Tools |
When some of the icons or toolboxes seem to be missing in MicroStation V8i / CONNECT Edition
In Microstation toolboxes can be shown or hidden. If you right click on the main tool palette you can check or uncheck the toolboxes on or off. If you open a toolbox and right click on a tool in the toolbox you can do the same.
Here is a short video how to do that in MicroStation V8i:
You can also open the list and select the missing tool from the list:
How to locate the missing tool or tool group in MicroStation CONNECT Edition:
please see this short video: https://youtu.be/AP1QFy61Sv4
NOTE: If tool is not discoverable it may be down to organization’s customization / configuration – Check MS_GUIDGNLIBLIST variable especially if it’s a custom tool that’s not available
