| Version: | 08.11.07.443 | ||
| Area: | Configuration | ||
| Subarea: | Workspaces |
If the MS_DEFCTBL variable is undefined what is the name of the color table that is used for the default.
If the MS_DEFCTBL variable is not set, the default color table used by Microstation is:
color.tbl, located in the folder: ...\workspace\system\data\
