RAM Connection CONNECT Edition v11.0 Release Notes
RAM Connection CONNECT Edition v11.02.00.013 Release Notes – Updated November 2017
Enhancements:
- AISC 360/341/358–16 update for all previously existing AISC connections.
- Horizontal bracing connections:
- Horizontal column-beam-brace connection
- Horizontal beam-beam-brace connection
- Horizontal X brace connection
- Users now have the ability to change the application user interface language from English to Spanish or Chinese and vice versa, once the software is installed.
- Documentation update. All RAM Connection manuals have been updated the latest features and GUI, including the tutorial examples.
Resolved Issues:
- Anchor placement in pinned base plates with HSS columns is validated to exclude positions inside the hollow section.
- BS 5950 Moment End Plate connection was crashing when using mini haunches. This has been fixed.
- Custom bolts per the Indian standard were not able to be created. This has been fixed.
- Custom anchor configurations were not being saved properly when closing the Connection Pad. This has been fixed and now custom anchor positions are saved correctly.
