| | Applies To | | |
| | Product(s): | STAAD.Pro | |
| | Version(s): | All | |
| | Environment: | N/A | |
| | Area: | Analytical Modeler | |
| | Subarea: | Modeling Solutions | |
| | Original Author: | Bentley Technical Support Group | |
This page contains Wikis related to Modeling in STAAD.Pro Analytical Modeling workflow. Wikis in this page are grouped based on the pages which are shown in the Analytical Modeler:
Geometry
- Modeling a Retaining Wall
- Connectivity Issues
- Difference Between Plate, Shell, and Surface Elements
- Total Joint/Element Limits Exceeded
- Modeling Corrugated Steel Plates
- Joint Coordinates Modified when Model Moved
- Model Shear Walls Using Plates
- Cannot Copy a Member, Node or do Transitional Repeat
- [[Modeling base plate with anchors in STAAD.Pro]]
- [[Identifying face numbers for Solid Elements]]
- [[How to check modelling error in Structure]]
- [[Can I analyze and design a hollow core slab using STAAD.Pro?]]
- [[How to change input units in STAAD.Pro CONNECT Edition ?]]
- [[Challenges involved in modeling with surface elements in STAAD.Pro]]
- Mesh generation error while adding an opening in the Parametric Models
- Box Culvert Modeling in STAAD.Pro
- Limitations of the curved beams in STAAD.Pro
- Magnifying or Scaling down a model
- STAAD.Pro Wall Analysis For Dams [TN]
- How to model Pile cap attached to batter and vertical piles in STAAD.Pro
- Plate Error - BADLY SHAPED, WARPED, NOT CONVEX, OR NOT NUMBERED COUNTER-CLOCKWISE
- Avoiding Stress Concentrations
- Change Model Units in an Existing Model
- Check Beam Connectivity Using the "Highlight Intersecting Beams" Tool
- Duplicated Nodes Warning
- [[Error - Member/Element cannot be a member of more than 10 groups]]
- How do I merge Two STAAD.Pro models?
- Modeling sheet pile in STAAD.Pro
- Plate Diaphragm - Flexible Diaphragm or Rigid Diaphragm
- Splitting Continuous Beams
- User Defined Grid System
- Machine Foundation Analysis
- [[Model Flat slab-drop cap in STAAD.Pro]]
- [[How to find the coordinates of two intersecting members]]
- [[How can I change / modify unit system?]]
- [[Use of larger numbers in joint coordinates in STAAD.Pro models]]
- [[How do I generate plate mesh while facing the situation stated below]]
- [[How to move a node or group of nodes by a certain distance.]]
- [[How can I convert surface elements to plate elements]]
- [[How do I model a slab having two different thicknesses such that their top faces are aligned?]]
- [[How to generate a solid mesh using a plate mesh]]
- [[Member, Plate and Solid - which one to use?]]
- [[Modeling intersection of two cylinders in STAAD.Pro]]
- [[Optimum Plate mesh]]
- [[Modeling a base plate on a concrete pedestal]]
- [[Can STAAD.Pro be used in designing a mat foundation?]]
- [[Length to thickness ratio of individual plate element]]
- [[Break Beams at Selected Nodes]]
- [[Creating Circular shape plates using Structure Wizard]]
- [[How can I renumber nodes, beams, plates, or solids in my STAAD.pro model?]]
Properties
- Section Properties not Entered for Member
- Steel Section Encased in Concrete or with Concrete Core
- Modify Section Database
- New Section Database
- [[“WARNING- TD or TB IS ZERO IN USER TABLE …”]]
- [[How to Merge Properties]]
- Creating a custom section in the User Provided Table (UPT)
- How Do I Assign WT Sections to Members In My Model
- [[Section Wizard Tutorial]]
- How to account for joists in stiffness analysis in STAAD.Pro?
- How to enter section properties for a non-standard or built-up shape as a User Table of type "General"
- The meaning of Ct value for the W shape
- Define the Orientation of the Local Axis
- [[IZ of prismatic section is missing for a Plane structure]]
- [[How to Add Specification to Selected Member Profile]]
- [[Steel Sections are missing]]
- [[STAAD.Pro Section database appears to be corrupted or greyed out]]
- [[How can I access sections from older AISC section databases in the STAAD.Pro CONNECT Edition?]]
- [[How to change default Section database as per User's need?]]
- [[Migrating existing custom Steel section databases to the STAAD.Pro CONNECT Edition]]
- [[Prismatic and General Section]]
- [[Backup section database after updating the STAAD.Pro CE]]
- [[Transfer user modified Section Database files to other system]]
- [[Section properties reported by the Section Wizard do not match with hand calculations]]
- [[Changing units in the Section Wizard]]
- [[St. Venant's Torsional Constant]]
- Create Section by Specifying Profile Points
- Model Solid Rods
- [[How to assign properties to solids?]]
Materials
- Create Material Macro
- [[ERROR***MATERIAL GROUP AND EXPLICIT CONSTANT SPECIFICATION CANNOT BE USED TOGETHER]]
- [[POISSON'S RATIO HAS NOT BEEN SPECIFIED]]
- [[Timber material is missing]]
- [[Modeling and orthotropic plate]]
- [[How to add a custom material permanently?]]
- [[An error DENSITY NOT PROVIDED. SELFWEIGHT COMMAND IGNORED reported in the Output file]]
Specifications
- Beam and Plate Orientation
- Compression Force in Tension Members
- Define Cable Section
- Model Slab on Top of Beams
- [[Different member release for different load cases]]
- [[What is member release in STAAD.Pro?]]
- [[Partial Moment Releases]]
- [[Concept of member offset in STAAD.Pro]]
- [[Fire Proofing Specification in STAAD]]
- HOW TO DEFINE MULTIPLE RIGID DIAPHRAGM AT SAME Y LEVEL
- I am trying to model a beam connecting to the flange of a column
- Assigning Offsets to Plate Elements
- Braces Carry Lateral Loads Only
- Member releases in an excel sheet
- [[Ignore the Stiffness of Certain Members]]
- [[INACTIVE MEMBER Command]]
- [[Master\Slave Command to Define a Rigid Diaphragm]]
- [[When two nodes are connected via the control/dependent specification, how can the forces and moments transferred by that connection be directly read?]]
- [[When I try to analyze my model it terminates with the error "invalid sparse matrix creation"]]
- [[ERROR NO REFERENCE LOAD CASE OF TYPE MASS/GRIVITY/DEAD/LIVE IS DEFINED FOR MASS MODELING]]
- [[Mass used to calculate the center of mass of the diaphragm]]
- [[Floor weight consideration for rigid diaphragm]]
- [[ERROR ACCIDENTAL LOAD SHOULD NOT BE DEFINED IN SEISMIC DEFINITION]]
- [[Moments of inertia Iz and Iy do not match the values in the AISC steel publication for the angle section]]
- [[Cracked section properties when modeling with concrete]]
- [[Applying control/dependent specification in non global directions]]
- [[Changing the Orientation of Beams and Plates]]
- [[How to change the local axis orientation X and Y for plates?]]
Supports
- Fixed and Enforced Support
- Scale Down Supports
- Specify Values of Stiffness for Compression and Tension at a Support
- Multiple Support Conditions in Same Model
- Aspects to Consider Analyzing Mat Foundations
- [[Multi Linear Spring Support]]
- [[What are Inclined Supports and how do I use them?]]
- Tension/Compression Only Spring Support
- Difference between Y and Y-ONLY type foundation support
- My Model Contains Compression Only Soil Springs In Which The Wind Loads Are Producing Very Large Displacements. How Do I Resolve This?
- [[Difference Between ELASTIC MAT and PLATE MAT]]
- [[Elastic Foundation Error 0550]]
- [[Is a spring in compression or tension?]]
Loading
- Applying Line Loads on Plates
- [[Applying concentrated loads on a plate element]]
- Defining Temperature Load
- Distributing Wheel Loads
- Total Weight of Plates
- Edit Load Rules for Auto Load Combination Generation
- Load Path Consideration
- Specify Seismic Weights Through Reference Load Cases
- How to convert a LOAD COMBINATION to a REPEAT LOAD
[[How to use loads of the same loading type in mutually exclusive combinations when using automatic load combination]]
[[Loads are not displayed in the STAAD.Pro graphical user interface]]
- [[How to use Mass model Generator]]
- [[How to generate floor loading on an inclined floor/roof ?]]
- A warning message while running the Eurocode Load Combination Generator appears
- Eurocode Load Combination Generator creates some unrealistic load combinations
- [[Setting Display units for load values in STAAD]]
- Modifying a Wind Load definition in the GUI
- Reference Loads An Introduction
- Change Units After Entering Loading Functions
- PRESTRESS vs POSTSTRESS member load in STAAD.Pro
- Rock Anchors and Post Tensioning
- [[Member Tension And Combination Load Cases]]
- [[What is a Fixed End Member Load?]]
- [[Reported Warnings in applied Uniformly Distributed Member Load]]
- [[Difference Between a Load Combination and a Repeat Load]]
- [[Eliminate Floor Load Warning]]
- [[Reference Load Case]]
- [[Seasonal Temperature loading]]
- [[Temperature Load and Alpha Value for Mean Temperature]]
- [[Temperature load on plate element]]
- [[WARNING - UNEXPECTED COMMAND IN LOAD DATA]]
- [[Why Am I Unable to Edit the Design Code in My Wind Load Definition?]]
- [[Load determination from displacement value]]
- [[Transfer load from slab to beam without modelling the slab]]
- [[Repeat load within a Repeat load case]]
- [[Apply loads on wall of silo]]
- [[Use of FLOOR LOAD vs ELEMENT LOAD]]
- [[Moving load on curved beam]]
- [[Wind load calculation process in STAAD]]
- [[Moving load generation for a wide truck]]
- [[Consider moving load not applied over a beam]]
- [[Wind load on Truss member]]
- [[Find out critical reaction for a moving load]]
- [[How to combine Moving Load with other existing Loads]]
- [[Wind load applied to member groups in STAAD]]
- [[Note indicating floor diaphragm is to be defined before wind definition]]
- [[Generating Load Combinations by using Eurocode]]
- [[Code selection for Wind Load generation is grayed out]]
- [[WARNING-NO MEMBERS IN SPECIFIED VERTICAL RANGE - in STAAD.Pro moving load generation]]
- [[Unit for Temperature Loading]]
- [[**WARNING-A MOVING LOAD THAT WOULD HAVE BEEN APPLIED BEYOND THE X AND Z RANGES]]
- [[Floor loading using Enclosed Zone option]]
- [[Hydrostatic Member Load along Local axis]]
Other
- Center of Gravity
- Convert "SET Z UP" to "SET Y UP"
- [[How to measure node to node distance and dimension beams in STAAD.Pro Connect Edition ?]]
- [[Cannot edit models created in the Physical modeler using the Analytical modeler]]
- [[How to determine the local Axes in created ‘InFill’ plates]]
- [[Not able to see certain entities in my model]]
- [[Turning off Labels]]
- [[Turning off numbers from some specific nodes/members/plates/solids in the Analytical Modeler]]
- [[STAAD commands are written in an extensive list in the input file]]
- [[Assigning Properties, Specification, and Design Parameters using Beam Groups]]
- Limitation on Number of Plates
- Make Tool Tips Visible
- Quickly find Total Number of Nodes & Beams in a Model
- Viewing Individual Floors
- [[How to turn on the global axis icon in STAAD.Pro?]]
- [[Post processing shows material property for all members]]
See also:
STAAD.Pro Analysis Solutions
STAAD.Pro Design Solutions
