| | Product(s): | MicroStation | |
| | Version(s): | CONNECT Edition | |
| | Environment: | N\A | |
| | Area: | Mesh | |
| | Subarea: | N\A | |
How to divide or split a Mesh element into smaller portions along a predefined cutting line.
- Select the Mesh Project tool (Modeling > Mesh > Modify Meshes > Mesh Project)
- In the Mesh Project Tool Settings set the Method to Trim and Keep Both
- Select the Mesh element to be Trimmed
- Select the cutting element and except
How to cut a mesh
Other language sources
| | Original Author: | Carl Myhill | |
