After creating a pdf print out in MicroStation, I would like to see it open automically right after the printing is done.
- Edit the pdf.pltcfg (open Print > File > Edit Printer Driver Configuration).
- In the Base Properties tab: Under Tab > General > Automatic Open Plot File After Creation > change to True.
- Save the file.
- Print dialog > Reload Printer Driver Configuration, for effect to take place.
Other Language Sources
Deutsch
