| Applies To | | |
| Product(s): | STAAD.Pro | |
| Version(s): | All | |
| Environment: | N/A | |
| Area: | Steel Design Codes | |
| Subarea: | IS:800-2007 | |
| Original Author: | Bentley Technical Support Group | |
This page contains a list of Wikis which are related to the Indian Steel Design codes (IS 800, IS 801, IS 802).
- STP Parameter per IS:800-2007
- Serviceability Check in Design According to IS800:2007
- Design of User defined section
- Addendum-1 to IS:800-2007
- [[Warning - The value of Fyld for member (cable) does not seem to be right]]
- [[Reason for difference in UC ratio for symmetrical model]]
- [[THE VALUE OF MOMENT AMPLIFICATION FACTORS KY OR KZ IS GREATER THAN 1.4]]
- [[MINIMUM WEB THICKNESS REQUIREMENT FOR SERVICEABILITY NOT ACHIEVED]]
- [[BASIC SECTION DIMENSONS HAVE NOT BEEN PROVIDED. MEMBER # XXX CANNOT BE DESIGNED]]
- [[Load Case # XX is already defined in a previous envelope. The load case of final envelope type will override previous envelope type attributes]]
- [[MEMBER - XXX IS SLENDER AND CANNOT BE CHECKED FOR MOMENT FORCES]]
- [[Deflection check of member # xx will not be performed as service envelope not provided]]
- [[Warning appears ‘The value of Fyld for member (cable) does not seem to be right’ during analysis]]
- [[IS 802 Design code warning]]
