| Version(s): | 10.00.00.25 | ||
| Area: | Dimension | ||
| Subarea: | General |
Dimension Radial tool has been removed from CONNECT. See Readme file to review deprecated and superseded features
Superseded and Removed Features
You can use the Dimension element tool
1.Go to File\Settings\User\Tool boxes-> Select Dimensions and press ok
2. Select Dimension element
3. Select the element. If element is a circle the element dimensioning will change to offer more options: dimension radius, dimension diameter, dimension diameter parallel
| Original Author: | Maria Munoz |
