Structural Synchronizer 11.00 Release Notes
Release Date:  3rd September 2019
Release Name: Structural Synchronizer CONNECT Edition V11
Release Version: 11.00.00.15
Download Instructions
Structural Synchronizer can be downloaded at the link here, or from Bentley Cloud Services. After signing into the CONNECTION Center, select Software Downloads under My Support. Once on the Software Fulfillment page, the installer can be located by performing a search on “Structural Synchronizer”. Direct Software Downloads link.
New Features
This release of ISM and Structural Synchronizer expands the possible workflows in ISM.
Support for Node Links
Node Links (Rigid Links) can now be written to and read from an ISM model with the ISM 8.0 API. Likewise, Structural Synchronizer now supports visualization and revision management of Node links.
Support for ISM API 8.0
This version of Structural Synchronizer works with version 8.0 of the Integrated Structural Modeling (ISM) API. This version of the ISM API is backward compatible to version 3.0.
Subscription Entitlement Service (SES)
This product version utilizes Subscription Entitlement Service, which is not supported by SELECT activation key(s). SES is a free service, featuring new behavior to enhance your organization’s user administration and security with mandatory user sign-in via CONNECTION Client to access the application. If you are already signed in to the CONNECTION Client, you have met this prerequisite. If you have not, please refer to the Administrator's Resource Center and/or contact your administrator for assistance in the registration and sign-in process.
Bug Fixes
This release of Structural Synchronizer includes the fixes described below.
