| Version: | V8 | ||
| Area: | Text | ||
| Subarea: | Fonts |
Are True Type fonts installed with MicroStation V8?
True Type fonts are not installed with MicroStation V8. MicroStation V8 uses the True Type fonts installed on the client, through the Operating System.
True Type Fonts are Windows fonts located in the Windows directory.
(C:\Windows\Fonts) These fonts are the same fonts as used in Word and other MicroSoft Products.
