| Version(s): | V8, V8i and CONNECT | ||
| Area: | Dimensions | ||
| Subarea: | Tools | ||
How to dimension the length of an arc?
In Dimension Setting-Units Format-Angle Format-Units- set Length.
Then to dimension the length of an arc use Angular Dimension. (Go to
Tools-Dimensioning-Angular or display Angular Dimensions tools from
Tools-Tool Boxes-Angular Dimensions and choose Dimension Arc Size,
Dimension Arc Location)
