RAM Elements CONNECT Edition v14.0.1.008 Release Notes
RAM Elements CONNECT Edition v14.0 Release Notes
RAM Elements CONNECT Edition v14.00.01.008 Release Notes – Updated November 2017
Enhancements:
  1. Users now have the ability to change the application user interface language from English to Spanish and vice versa, once the software is installed.
Resolved Issues:
  1. AISC Section E4 axial compression capacity for T section with principal axes rotated was calculating the capacity with the incorrect section properties. This has been fixed and now the axial compression is calculated correctly regardless of the principal axes.
  2. AISC torsion capacity under AISC DG9 was being reported with force units instead stress. This has been fixed.
  3. AISC user input Cb values were ignored. This is fixed now and the Cb values entered by the user are being used during design.
  4. AISC member with no torsion being checked for AISC DG9. Although this is correct as the DG9 checks torsion using normal and shear forces, this was causing some confusion and a conservative design as the guide uses elastic limits. Now if the member does not have torsion, these checks are ignored.
