The following issues were addressed in RAM Elements V8i 12.05.01.18:
- Fix Kc calculation for non slender webs
- Fix member loads imported from RSS
- Fix Horizontal soil pressure forces at toe
- Fix Index out of bounds while optimizing
- Fix hoops warning during verification
- Fix Tool button to set the frame 3 to sway
- Fix Print to File option name error while saving
- Fix concentrated load at member ends
- Fix member end conditions for steel design
