| | Product: | MicroStation | |
| | Version: | V8, XM, V8i, CONNECT | |
| | Environment: | N\A | |
| | Area: | View | |
| | Subarea: | General | |
How to copy one view properties into another view.
Option 1
- Select the "Copy View" icon in "View Control" Toolbox or "View" Toolbox of your view.
- Select the source view.
- Select the destination view(s) to which to copy the source view.
Option 2
- Go to Utilities > Key-in
- Key-in Copy View and select source view, then select destination view. The view properties are copied.
Reference File Levels Not Remaining Turned On After Performing A Copy View
Other language sources
| | Original Author: | Bentley Technical Support Group | |
