| Version: | XM, V8i, CONNECT | ||
| Area: | View | ||
| Subarea: | View Navigation |
The view is not rotating as expected
When applying a rotation (Top, Right, etc.) to a view the result is not as expected. The view appears rotated differently.
Maybe ACS context lock is on?
It is possible that the ACS context lock is on. This would result in the view being rotated relative to the active ACS, not the design file coordinates.
This can be changed with the key-in LOCK ACSCONTEXT ON|OFF|TOGGLE to turn this setting on/off or toggle it.
