| | Product: | MicroStation | |
| | Version: | V8i, CONNECT | |
| | Environment: | N\A | |
| | Area: | UI Customization | |
| | Subarea: | General | |
How do you change the background color of a DWG file?
- When opening the DWG file in the File Open dialog select the Options.
- Expand the Basic options and you will see Model Space and Paper Space. Expand both of these options.
- Select Design Background Color for Model Space and Sheet Background Color for Paper Space.
- Select OK and open the file.
Other language sources
| | Original Author: | Bentley Technical Support Group | |
