| Version(s): | ALL | ||
| Environment: | ALL | ||
| Subarea: | Properties | ||
| Original Author: | Abhisek Mandal, Bentley Technical Support Group | ||
I am using section sizes that are not current, (they are historical sections). I have found out that I can update the section database so my sections are inputted here which I can then use to add/assign. I wanted to ask if there is a way that the section database I have updated on my computer can be used by other users in the company on their computers? I have checked and other users are unable to see the properties I have inputted when they open the model on their machines. What may be the solution here?
The details of sections are stored in some .db3 file in below location.
C:\ProgramData\Bentley\Engineering\STAAD.Pro CONNECT Edition\Sections
Program data is a hidden folder and you need to unhide it from settings. Below link from Microsoft also provide details on how to unhide a hidden folder.
https://support.microsoft.com/en-us/windows/view-hidden-files-and-folders-in-windows-97fbc472-c603-9d90-91d0-1166d1d9f4b5#WindowsVersion=Windows_10
You need to go to that location and copy the edited .db3 file and share with other users. They need to paste the same in the same folder path as shown above. Then the new sections will be read by the program.
Some related wiki can be found in below links.
Backup section database after updating the STAAD.Pro CE
How to add a new section database to STAAD.Pro
Update for STAAD.Pro 2023:
