| Version(s): | CONNECT | ||
| Area: | CONNECT Advisor | ||
| Subarea: | N\A |
How to disable the automatic startup of CONNECT Advisor when opening the MicroStation?
Open the CONNECT Advisor via the icon under the Help menu of MicroStation:
This will stop CONNECT Advisor opening when you next launch the application.
CE U7 - How do I stop CONNECT Advisor starting everytime I open a file?
