| Product(s): | MicroStation Connect, and all Power Platform Products | ||
| Version(s): | CONNECT Edition Versions | ||
| Environment: | Windows 10, German, Dutch, Italian, Spanish, Finnish, English | ||
| Area: | Configuration | ||
| Subarea: | General |
[24 July 2018]
Microsoft issued fix KB4340917 which is available via Windows Update or as a download for use by system administrators.
The issue fixed that related to Bentley is:
"Improves the ability of the Universal CRT Ctype family of functions to handle EOF as valid input."
Users can do the following (subject to having appropriate permissions and, where appropriate, consultation with IT support):
On Friday June 8th, Microsoft has started to block offering up Windows 1803 Update to our customers as an automatic update (until the resolution is properly resolved).
If the following registry key is found on a Win10 machine, Microsoft will not offer up Windows 1803 as an automatic update.
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\Bentley
However, it will not block a user / admin who “checks for updates” from updating if they choose.
Other Language Sources
| Original Author: | Regie Wallace |
