| Version: | 07.01.04.16 or later | ||
| Area: | Cells | ||
| Subarea: | General |
When placing cells with data fields that data fields can no longer be
manipulated.
Product: MicroStation J7.1
Version: 07.01.04.16
Area: Cells
Cells were placed as shared cells.
Drop the existing cells to normal cells, and uncheck "use shared cells" in the cell library dialog.
