RAM SS 2024 and Hilti Profis
Starting with RAM Structural System 2024 the HILTI Profis link is no longer installed by default. Follow these steps to use the link from RAM Foundation:
C:\Program Files\Bentley\Engineering\RAM Structural System\Prog\ProfisWebInterface
For more information on this interface refer to Designing Frame Base Plates with Hilti PROFIS Engineering in RAM Structural System
Current version of ProfisEngineeringImport.exe on 1/8/26 is 2.0.17.0
