| Version(s): | V8i | ||
| Area: | Cells | ||
| Subarea: | General | ||
When trying to replace cells with cells from a converted V7 cell library, they appear with a scale of one, but required scale is 50.
Scalefile.mvba will rescale the cells in the file to the correct scale.
This mvba can be found here:
http://communities.bentley.com/communities/other_communities/bentley_library/m/bentley_library_utilities/138914
