| Version(s): | V8i | ||
| Area: | Visualization | ||
| Subarea: | Materials | ||
| Original Author: | Craig Calvin, Bentley Technical Support Group | ||
After assigning or attaching a material to an object, it appears as a solid color.
The material may or may not display correctly in the material preview.
The material may appear to be a solid color due to the scaling applied to the pattern image in relation to the model's working units.
Step 1: Make sure the model is using correct units
1. Go to: Settings > Design File > Working Units
2. Set the appropriate Working Units
3. Click OK
4. Save SettingsMethod 1: Select File > Save Settings
Method 2: Shortcut <Ctrl-F>
Step 2: Make sure the pattern map image is scaled appropriately
Option 1 - Adjust the material pattern map values dynamically in a view
To Access
Menu: Tools > Visualization > Materials > Dynamically Adjust Map
Tasks: Visualization > Dynamically Adjust Map
Shortcut: Material Editor > Pattern Map Editor dialog
Key-in: MATERIAL MAP DYNAMIC
Option 2 - Change the material pattern map values in the Pattern Map Editor dialog
- Open the Material Editor dialog
- Select the material
- Select the General tab
- Click on the Pattern Map icon to open the Pattern Map Editor
- In the Pattern Map Editor dialog, expand the Units section
- Change the X & Y sizes as needed
MicroStation Wiki - Assigned material will not render
MicroStation Help - Dynamically Adjust Map
MicroStation Help - Map Editor Dialog
MicroStation Help - Map Editor Dialog, Units and Mapping Sections
MicroStation Help - Design File Settings Dialog, Working Units Category
Product TechNotes and FAQs
