| Version(s): | V8i | ||
| Environment: | Windows 7 32 bit,Windows 7 64 bit | ||
| Area: | Programming | ||
| Subarea: | VBA | ||
| Original Author: | Tristan Anderson, Bentley Technical Support Group | ||
Background Information
Property data by specifications contain values that should not be displayed in a drawing, or it should generally make all technical data of certain cells disappear.
Steps
Below is an example in which all property data is hidden in cells which were selected in advance.
The example examines only the previously selected cells or dummy cells on the .GetSelected method from the attribute .IsHidden = True.
The number of attribute data is counted and displayed in the message center at the end. If nothing is selected a message will appear.
Sub TagsSelOff()
Dim Ee As ElementEnumerator
Dim found As Boolean
Dim otags() As TagElement
Dim count As Long
count = 0
Set Ee = ActiveModelReference.GetSelectedElements
Do While Ee.MoveNext
found = True
If Ee.Current.IsCellElement Or Ee.Current.IsSharedCellElement Then
If Ee.Current.HasAnyTags Then
otags = Ee.Current.GetTags
For i = LBound(otags) To UBound(otags)
If otags(i).IsHidden = False Then
count = count + 1
otags(i).IsHidden = True
otags(i).Rewrite
End If
Next
End If
End If
Loop
If Not found Then
MessageCenter.AddMessage "No elected Members", , msdMessageCenterPriorityError
Else
MessageCenter.AddMessage "There were " + str(count) + " pieces of attribute data removed", , msdMessageCenterPriorityInfo
End If
End Sub
Searching and Evaluating Data in a drawing with VBA Part 10 - Reading Attribute Data
