| Version(s): | V8i and CONNECT Edition | ||
| Area: | Batch Processing | ||
| Subarea: | N\A | ||
Is there configuration variable to set the destination directory
in batch converter? As it is now you need to set it everytime you
select the utility.
Select the destination directory, select the files and save the
Conversion Job. When creating a new job open the saved job
and reselect new files.
How to include subfolders in Batch Converter
