| Version(s): | V8, V8i, CONNECT Edition | ||
| Area: | Configuration | ||
| Subarea: | Workspaces | ||
How to disable MS_V7AUTOSAVE and MS_V7AUTOSAVE_NODIALOG
Go to Workspace > configuration and set the MS_V7AUTOSAVE to a very high number and set the MS_V7AUTOSAVE_NODIALOG to 1.
