| | Applies To | | |
| | Product(s): | MICROSTATION | |
| | Version(s): | V8i, CONNECT | |
| | Environment: | N\A | |
| | Area: | Dimensions | |
| | Subarea: | Dim Styles | |
| | Original Author: | Bentley Technical Support Group | |
How to tell where the dimension styles are being read in from, either a dgnlib file or the current design file?
- Hover the cursor over the dimension style in the Dimension Styles dialog box, a tool tip will appear displaying the file name path of the dimension style if it from a dgnlib file.
- If the style was created in the current design file, a tool tip of local style will appear.
