| Version(s): | 08.11.09.459 | ||
| Area: | DWG | ||
| Subarea: | Save | ||
| Original Author: | Craig Calvin, Bentley Technical Support Group | ||
When saving a DGN to DWG the following error appears:
"Unable to open seed file: <FileName>.dwg"
The "Save as DWG/DXF Options" is set to use a DWG seed file that is unavailable.
Make sure the "DWG Seed File" used in the "Save As DWG/DXF Options" dialog is valid.
(i.e. Make sure you have correct permissions and the path/file exist.)
To change the seed file used when saving as DWG/DXF:
Make sure the following configuration variables contain valid directories and files:
MS_DWGSEED
MS_DWGSETTINGSFILE
MS_DWGDATA
MS_DWGSYSTEMDATA
MicroStation Wiki - Batch Convert to DWG Failed "Unable to save…Status 77847"
MicroStation Wiki - MicroStation V8i Variables
MicroStation Help - DWG and DXF related Configuration Variables
Other Language Sources
External Links
Comments or Corrections?
