| Version: | V8, 2004, XM, V8i, CONNECT Edition | ||
| Area: | Levels | ||
| Subarea: | General |
When in V7 workmode, I set up my levels with the desired Color, Line Style and Line Weight in the Level Manager. However, after saving, closing and reopening the file, all attributes (Color, Style and Weight) are set back to 0. Can you use ByLevel Attributes in a V7 file?
V7 files do not have ByLevel functionality like V8 files do. ByLevel symbology is not supported in the V7 format, but it is possible to use the attributes from a V8 level library in a V7 file.
Procedure:
The active attributes should now show ByLevel.
Note: This will not set the status of by level for any existing element attributes. This only applies the level settings from the library to new elements placed in the design.
