| Version(s): | V8i, CONNECT | ||
| Area: | Printing | ||
| Subarea: | Driver/HPGL2 | ||
Raster data printed via MicroStation plotting produces incorrect output when moving data between V7 and V8. Files that plot correctly in MicroStation v7, plot incorrectly from MicroStation v8.
This problem was corrected by using the Bentley hpglrtl.plt driver. The hpglrtl (rtl = raster transformation language) is recommended when plotting raster data in most instances.
