Todd Myhre, Murray Fredlund - 2017 "CASE STUDY – 3-D FLOW MODELING OF THE SNC LAVALIN EARTH DAM" Canadian Dam Association 2017 Annual Conference, Kelowna, British Columbia, October 16-18, 2017
Todd Myhre, Murray Fredlund - 2017 "An Improved Methodology for Meshing 3-D Earth Dam Structures" ICOLD 2017, Prague, Czech Republic,July 3-7, 2017
Shawn, Meng, Murray Fredlund - 2016 "Finite Element Groundwater Seepage Code Verification" Tailings & Mine Waste 2016, Keystone, Colorado, October 2-5, 2016
Murray Fredlund, Rob Thode - 2015 "Modeling of Seepage through Segregating Waste Rock: Part II" Tailings & Mine Waste 2015, Vancouver, BC, October 26 to 28, 2015
Nicolas Echeverría, David Romo, Iván Suazo - 2015 "Hydraulic performance of permanent heap leach with intermediate drainage system" Heap Leach Solutions - 2015, Reno, NV, USA, September 14 - 16, 2015
M.D. Fredlund, D.T.Q. Tran, and D.G. Fredlund - 2015 "The calculation of actual evaporation from an unsaturated soil surface" 10th International Conference on Acid Rock Drainage, Santiago, Chile, April 21 - 24, 2015
D.G. Fredlund and Fexia Zhang - 2013 "Combination of Shrinkage Curve and Soil-Water Characteristic Curves for Soils that Undergo Volume Change as Soil Suction is Increased" 18th International Conference on Soil Mechanics and Geotechnical Engineering, Paris, Sept 2-6, 2013
Murray Fredlund, Rob Thode - 2013 "Modeling of Seepage through Segregating Waste Rock: Part I" Tailings & Mine Waste Conference, Banff, AB, Canada, November 3 - 6, 2-13
Peter Guerra, Daniel Priestley, Murray D. Fredlund - 2012 "3D Groundwater Seepage Analysis of a Levee Intersection" Canadian Dam Association Annual Conference, Saskatoon, SK, Canada, September 2012
G. Siemens, R. J. Bathurst - 2010 "Numerical parametric investigation of infiltration in one-dimensional sand-geotextile columns" Royal Military College of Canada, Kingston, ON, Canada, 2010
Murray D. Fredlund, Rob Thode - 2010 "Effect of Mesh Resolution on Long-Term Water Balance Calculations" Fifth International Conference on Unsaturated Soils, September 6 - 8, 2010
D.G. Fredlund, S.L. Houston, Q. Nguyen, M.D. Fredlund - 2010 "Moisture Movement Through Cracked Clay Soil Profiles" Geotechnical and Geological Engineering, Volume 28 Number 6, November 2010
Evan W. Jones, Yih H. Koh, Bradley J. Tiver, Marcus A. H. Wong - 2009 "Modelling the Behaviour of Unsaturated Saline Clay for Geotechnical Design" Adelaide University Student Project, 2009
Guan-Wei Jia, Tony L.T. Zhan, Ph.D., Yun-Min Chen, Ph.D. and D.G. Fredlund, Ph.D. - 2009 "Influence of Rainfall Pattern on the Infiltration into Landfill Earthen Final Cover" International Symposium on Geoenvironmental Engineering, September 8-10 2009, Zhejiang University, Hangzhou, China
Murray Fredlund, Ph.D, P.Eng., Gilson Gitirana, Ph.D. and Hung Pham, Ph.D. - 2008 "A Methodology For Applying Probability Theory To Unsaturated Hydraulic Properties as the Foundation for Seepage Analysis" GeoCongress 2008, March 9-12, 2008, New Orleans, LA, USA
Hung Q. Vu, Yafei Hu, and D.G. Fredlund - 2007 "Analysis of Soil Suction Changes In Expansive Regina Clay" 60th Canadian Geotechnical Conference and 8th Joint IAH-CGS Conference, October 21-24, 2007, Ottawa, ON, Canada
Gitrana, G. Jr., M.D. Fredlund & D.G. Fredlund - 2006 "Numerical Modeling of Soil-Atmosphere Interaction for Unsaturated Surfaces" Fourth International Conference on Unsaturated Soils, April 2-5, 2006, Carefree, AZ, USA
Chen, Q. and L.M. Zhang - 2006 "Three dimensional analysis of water infiltration into the Gouhou rockfill dam using saturated-unsaturated seepage theory " Canadian Geotechnical Journal, 43: 449-461
Fredlund, D.G., and Gitirana, Jr. G.F.N. - 2005 "Unsaturated Soil Mechanics as a Series of Partial Differential Equations" Proceedings of the International Conference on Problematic Soils - GEOPROB 2005, North Cyprus, May 25-27,2005: pp. 1-28.
Gitirana, G.G., Fredlund, M.D., Fredlund, D.G. - 2005, "Infiltration-Runoff Boundary Conditions In Seepage Analysis" Canadian Geotechnical Conference, September 19-21, Saskatoon, Canada
Szilagyi, J. - 2004 "Vadose zone influences on aquifer parameter estimates of saturated-zone hydraulic theory" Journal of Hydrology, 286: 78-86.
Ebrahimi-B, N. , G.F.N Gitirana Jr., D.G. Fredlund, M.D. Fredlund, L. Samarasekera - 2004 "A Lower Limit for the Water Permeability Coefficient" 57th Canadian Geotechnical Conference and 5th Joint IAH-CGS Conference, October 24-27, 2004, Quebec, QC, Canada
Fredlund, M.D. - 2004 "Finite Element Stochastic Analysis" 57th Canadian Geotechnical Conference and 5th Joint IAH-CGS Conference, October 24-27, 2004, Quebec, QC, Canada
M.D. Fredlund, J. Stianson & M. Rykaart - 2003 "Automatic Mesh Refinement in the SVFlux and ChemFlux Software Packages" UNSAT Asia 2003
R. S. Mansell,* Liwang Ma, L. R. Ahuja, and S. A. Bloom - 2002 "Adaptive Grid Refinement in Numerical Models for Water Flow and Chemical Transport in Soil: A Review" Vadose Zone Journal, 1:222–238
M.D. Fredlund, J. Stianson & M. Rykaart - 2002 "Applications of Automatic Mesh Refinement in the SVFlux and ChemFlux Software Packages" 55th Canadian Geotechnical Conference and 3rd Joint IAH-CNC/CGS Conference, October 20-23, 2002, Niagara Falls, ON, Canada
N.T.M Thieu, M.D. Fredlund, D.G. Fredlund & V.Q. Hung - 2001 "Seepage Modeling in a Saturated/Unsaturated Soil System" International Conference on Management of the Land and Water Resources, MLWR, October 20 - 22, 2001 - Hanoi, Vietnam
D.G. Fredlund - 2000 "The 1999 R.M. Hardy Lecture: The implementation of unsaturated soil mechanics into geotechnical engineering." Canadian Geotechnical Journal, v37(5), pp. 963-986
D.G. Fredlund, Anqing Xing & Shangyan Huang - 1994 "Predicting the permeability function for unsaturated soils using the soil-water characteristic curve" Canadian Geotechnical Journal, v31, pp. 533-546
