| Version(s): | 08.11.09.XXX, 10.XX.XX.XX | ||
| Area: | Configuration | ||
| Subarea: | General | ||
| Original Author: | Bentley Technical Support | ||
Error message when starting MicroStation
"Unable to resolve digital signature get certificate ex from lib tool subs for "protect"
Check the 'Short Cut' used to start the program that its " Start In " directory is pointing to the current MicroStation Install directory.
