| Version(s): | 08.11.09. XXX, 10.XX.XX.XX | ||
| Area: | DWG | ||
| Subarea: | Open | ||
| Original Author: | Bentley Technical Support | ||
All dwg files open with red background color regardless of DWG Open options for Background color.
Copy acadcolor.tbl file from the .../Workspace/System/data folder, rename to DwgDisplayColors.tbl. Place new file in .../home/prefs/dwgdata folder (or where ever MS_DWGDATA is pointing to) to replace old file.
