| Version(s): | 08.11.09.XXX, 10.XX.XX.XX | ||
| Area: | Text | ||
| Subarea: | N\A | ||
| Original Author: | Bentley Technical Support | ||
How to disable the use of True Type Fonts, USTN Fonts and/or SHX Fonts in V8
Version: 08.11.09.XXX, 10.XX.XX.XX
Product: MicroStation
Area: Font
In workmode.cfg you can find a list of settings.
CAPABILITY_TEXT_FONTS_TRUETYPE
CAPABILITY_TEXT_FONTS_RSC
CAPABILITY_TEXT_FONTS_SHX
You should make changes with these settings at the standards, project, or user configuration level.
For example, you can any of the following to your PCF:
_USTN_CAPABILITY < -CAPABILITY_TEXT_FONTS_TRUETYPE
_USTN_CAPABILITY < -CAPABILITY_TEXT_FONTS_RSC
_USTN_CAPABILITY < -CAPABILITY_TEXT_FONTS_SHX
This will remove the TT fonts, USTN fonts, and SHX fonts, respectively, in the fonts list.
