In a DWG drawing with clipped reference
 Product(s):MicroStation
 Version(s):08.11.09.XXX, 10.XX.XX.XX
 Environment: N\A
 Area: DWG
 Subarea: General
 Original Author:Bentley Technical Support
In a DWG drawing with clipped reference files. The clip boundary is
displayed and can not be selected or turned off.
This is controlled by the DWG variable xclipframe. In the key-in browser
type "DWG xclipframe 0" to turn the display of the reference clip
boundary off. Setting it to 1 to turn the display of the reference clip
boundary on.
