| Version(s): | 08.11.09.xxx | ||
| Area: | Dimensions | ||
| Subarea: | Dim Styles | ||
| Original Author: | Bentley Technical Support | ||
Are there key-ins available to open the older version of Dimension Style dialog box?
Product: MicroStation
Version: 08.11.09.xxx
Area: Dimension/Measure
The key-in: DIALOG DIMSETTINGS OPEN will open the old dimension style dialog box.
The key-in: DIALOG DIMSTYLE OPEN will open the new dimension style dialog box.
Annotations Wiki - MicroStation Dimensions
