| Version(s): | 08.11.09.xxx, 10.xx.xx.xxx | ||
| Area: | Mesh | ||
| Subarea: | N\A | ||
| Original Author: | Bentley Technical Support | ||
What is the minimum value that the Maximum number of edges can have set for this field?--When generating a mesh, what is the minimum value that the Maximum number of edges can have set for this field?
The minimum number of edges is 3.
