| Version(s): | 08.11.09.xxx | ||
| Environment: | Windows 7 32 bit,Windows 7 64 bit | ||
| Area: | Programming | ||
| Subarea: | VBA | ||
| Original Author: | Bentley Technical Support | ||
Symptoms
If in VBA a new text element is generated, it is often necessary to change its properties including the font. It may happen that this change isn't made, for example, the following sequence will not be executed:
Sub TextFontNotChanged()
Dim tEle As TextElement
Dim oFont As Font
Set tEle = CreateTextElement1(Nothing, "hello", Point3dZero, Matrix3dIdentity)
Set oFont = ActiveDesignFile.Fonts("Verdana")
Set tEle.TextStyle.Font = ActiveDesignFile.Fonts("Verdana")
ActiveModelReference.AddElement tEle
End Sub
However, when the new text font initially allocates an object of type "text font", it will work, as shown in this VBA routine:
Sub textfontchange()
Dim oFont As Font
Set tEle.TextStyle.Font = oFont
End Sub
