| Version: | 08.11.09.xxx, 10.xx.xx.xxx | ||
| Area: | DWG | ||
| Subarea: | Save |
When converting (save as) a file from dgn to dwg, the name of the reference file appears in the name of the levels.
In ‘Save As DWG’ Options Dialog
Select: Reference Tab
Select:
“Copy levels during Merge” and
select
“ if not found”
| Original Author: | Derval Canny |
