| Version(s): | 08.11.09.xxx, 10.xx.xx.xxx | ||
| Area: | View | ||
| Subarea: | Saved Views | ||
| Original Author: | Bentley Technical Support | ||
When creating a saved view and applying the Saved View, the proportions
of the Saved View change.
For example : I use 2 wide screens with long horizontal views, then I
create Saved Views and send the file to a colleague.
My colleague has one screen, opens the file and then applies the Saved
View and only half of the Saved View displays,
User wants to know how to correct the proportions when applying saved
views.
When you apply the Saved View Option turn on the options "Window and
Aspect ratio"
